This is designed for Vantage 8.03.04 Users
If using Vantage 8.03, replace oe101b with oe100b
Copy the following files for backup
X = your drive letter - like C or D
Make the follow directories:
X:\epi-backup\properties
X:\epi-backup\config
Copy the following files:
Copy X:\epicor\oe101b\properties\*.* X:\epi-backup\properties
Copy X:\epicor\mfgsys803\server\config\*.* X:\epi-backup\config
Copy X:\epicor\oe101b\startup.pf X:\epi-backup
Install your software:
Use X:\epicor\oe101b as the directory for Progress
Use X:\epicor\oe101b_wrk as work directory
Follow the prompts until installed
Install Progress Service Pack(s)
Copy back the properties, config, and startup.pf files
Copy X:\epi-backup\properties\*.* X:\epicor\oe101b\properties
Copy X:\epi-backup\\config\*.* X:\epicor\mfgsys803\server\config
Copy X:\epi-backup\startup.pf X:\epicor\oe101b
Carl Peterson
sanfranc415
Sent: Monday, January 14, 2008 12:03 PM
Subject: [Vantage] Re: OpenEdge 101B SP3 failed during install.
I noticed after uninstalling OpenEdge, all the appservers and
databases are removed. Is there a way to backup this configuration
and restore them after reinstalling?
--SF
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Calvin
Carl Peterson
sanfranc415
--SF
>"sanfranc415" <sanfranc415@> wrote:
> I ran into the same exact problem.
> It started out as un problem unrelated to OpenEdge, but the Epicor
> support folks follow a scripted path, which always starts with "You
> need the latest patch..."
> Luckily we were only testing 8.03 (we're in the middle of a conversion
> from 4.41 to 8.03) and could be down for the two whole days and several
> WebEx sessions) that Epicor took to get it resolved.
> During the Install of OE101b SP3, the progress would get to that magic
> 11% and then just quit.
> It took the following to finnaly get SP3 installed
> 1. Reboot server
> 2. Uninstall OE101b (requires going in to the Explorer tool and stoping
> the DBs, then stopping the Windows Services)
> 3. Reboot Server
> 4. Install OE101b (no service pack)
> 5. Stop OE DBs and services
> 5. Install OE101b SP2 (required for SP3 installation)
> 6. Stop OE DBs and services
> 7. Install OE101b SP3
> 8. Reboot server
> I don't know if every one of those steps was necessary, but doing them
> all worked.
> And all of that was for a problem that still existed after the SP3
> upgrade.
> Calvin
> >[Non-text portions of this message have been removed]
> > I was wondering if anybody is experiencing problems installing SP3 for
> > OpenEdge 101B? I've deleted the temporary folder, work directory, and
> > even rebooted the machine, but after the installation starts,
> > OpenEdge101BSP3 gets to 11% and just quits. Nothing is logged and no
> > error messages are displayed.
> > Now, I can't run the AdminTools because I'm getting an a memory
> > mismatch error when I start the Admin Tools.
> > Thanks,
> > --SF
