I need to know if it possible to access a dashboard from another dashboard. As an example I have a Advanced dashboard but I want the capability if someone selects the Sales Order Number, they can select one of many dashboards that use the Sales Order Number as a key of the report.
If this is possible, what are the steps to make this happen. In addition, can a limit the list of dashboards available to select from?
Have you tried adding your dashboards to the context menu for sales order number.
Anywhere on the system such as the order entry form or a dashboard where the sales order number appears you can then right click open with and select your desired dashboard. The dashboard will also sync using publish and subscribe if you change the base sales order number on the first screen.
