My concern is with ensuring that the process requirements remain
intact. If they are identified by the operation code, it is easier to
see what operations are required and in what order for each process.
I tried creating templates for each process, but can't pull in
details from multiple templates or jobs. No matter which way it is
accomplished, our jobs will have 50 to 150 operations.
My question is what are the drawbacks to having 300 operations in the
system compared to 50 to 75 operations?
The consultant says you must enter setup and production times each
time you use it. Doesn't the data from the operation standards get
entered as the default? She also suggests setting up templates that
contain all of the processes, pulling it across then deleting what
you don't want.
There is also the issue of translating the existing setup (9500) &
WIP operations (345,000).
you don't want.
--- In vantage@yahoogroups.com, "c.chest" <c.chest@...> wrote:
> I side with the consultant who says it is too many operations. If
> the SBTBake operations are basically the same, you can add it to
your
> router (MOM) as many times as you want to, each time you do, it
will
> give you an operation number...10, 20, 30, etc. If there is
> something different used in the operation, you can maintain that at
> the Resource group, resource level. That's the way we do ours. We
> might have 20 different machining operations, but we just assign
one
> operation, machining and then designate which machine by the
resource
> group or resource,which then depicts what the operation is, like
> Vertical Mill would tell us it is milling. All of the costs and
> reporting information is done by the resource group/resource. I
> don't think what you're doing is wrong, just too much maintainence
in
> my opinion.
