Opportunity / Quote Entry Questions
Thanks, Greg and Scott. Looks like I've got some work to do!
Eric
--- In vantage@yahoogroups.com, Greg Payne <gpayne@...> wrote:
> you can do both of these with some programming.
> I have been playing with Quotes and was able to make one of my updatable baqs alter the QuoteOpr.OprSeq and QuoteOpDtl.OprSeq. I was able to change the labor on the operation after I moved it and the worksheet updated properly. If I was going to this in the entry screen I would add a field for New Operation Sequence and then on update change the OprSeq on both tables.
> On QuoteAsm.GetNewOperation you can read the resource group and set the standard or the operation and set that standard and setup time.
> Good Luck.
> Greg
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Scotty K.
> Sent: Monday, December 16, 2013 3:33 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Opportunity / Quote Entry Questions
> Eric,
> We are heavy users of Quote Entry and ....
> 1) We have not found a way to re sequence operations. When you add an operation, you can change the sequence number before saving and then re sequence all operation numbers.
> 2) This is normal functionality. You could have more than one standard, and you'd want users to select between the two. When you start running reports and doing mass updates, it's good that this field doesn't auto populate. We tell our users to always select a standard unless there is some extra-ordinary reason not to. This allows us to do a mass update to standards via DMT, without changing manually entered production standards.
> Scott
> On Mon, Dec 16, 2013 at 2:13 PM, ericslagter <eslag156@...<mailto:eslag156@...>> wrote:
> Hi,
> I have a couple of questions regarding the Opportunity / Quote Entry screen and I hope someone can help.
> 1). Is it possible to resequence operations after they have been added to the Mfg Details for the part? In other words, if we have three operations (10, 20, and 30), is it possible to move Operation 30 to 15 so that it falls in between operations 10 and 20? I cannot figure out if this is possible.
> 2). We'd like to use Operation Standards to default in Setup Times for each operation. I've set up Operation Standards for each operation and attached them to the Resource Group. However, when we select an Operation on the quote, the Operation Standard field stays blank. When we select the Operation Standard manually, the setup time then defaults in. Shouldn't the Operation Standard automatically default if it's selected on the Resource Group ?
> Thanks!
> Eric
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
Hi,
Thanks!
Eric
Eric,
Â
Â
Scott
On Mon, Dec 16, 2013 at 2:13 PM, ericslagter <eslag156@...> wrote:
Â
<div>
  <p>Hi,<br>
Thanks!
Eric
</div>
<div style="color:rgb(255,255,255);min-height:0px;"></div>
Good Luck.
Greg
Eric,
Scott
Hi,
Thanks!
Eric
