I still don't know how to get the CRTL+F to work, but I did find a
work around. I figured out that %E represents ALT on my scanner,
contrary to the documentation I've found. And I notice that I could
achieve the results I wanted with the CRTL+F by doing an Alt+E+F,
which was to open the find dialog. So my problem is solved. Thanks
to everyone who tried to lend a hand.
Brian Stenglein
Clow Stamping Co.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...> wrote:
> The following site is a little more clear about the Ctrl keys.
Whether they can be scanned in another question. But Ctrl-F should
be CHR(6) (or whatever report command produces chacters from ASCII
decimal code in your particular reporting tool).
> http://www.bbdsoft.com/ascii.html
> The bigger question is how the scanner interprets the "chracter".
My Welch-Allyn scanner book shows the CTRL "pairs" as being coded
with a preceeding $ as in $F for the ACK character which is what a
Ctrl-F is. The same table shows %B and %C for FS and GS characters
so I am assuming a barcode (in Code 39) of *$F* should work. The
original post didn't mention if this was tried.
> -Todd C.
> -----Original Message-----
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Monday, August 29, 2005 3:11 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: OT Barcode Tricks
> Under the files section of this group. Under the Misc Folder. It
is
> called Barcode.xls.
> By the way, I did figure out how to get the Find Dialog to open,
but
> not with CTRL+F. I figured out through trial and error that %E
> represents ALT. I used ALT+E+F to open the Find Dialog. I'd still
> be curious to know how to use CTRL if anyone knows.
> As of now I've got my problem figured out.
> Thanks,
> Brian Stenglein
> --- In vantage@yahoogroups.com, "Cliff Drumeller" <cliff@m...>
wrote:
> > Brian
> > Your handy document in the files section of Yahoo or Epicor ??
> > Cliff
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of Brian Stenglein
> > Sent: Friday, August 26, 2005 1:26 PM
> > Subject: [Vantage] OT Barcode Tricks
> > I know this, or things similar to this, have been discussed in
this
> > group several times in the past. I did find a handy document in
> the
> > files section to help me along, but I am still having
difficulties
> > adding "special keys" to a barcode.
> > I want to be able to scan a barcode, have the PN entered into a
> > field, have the enter key hit, the escape key hit and the tab key
> hit.
> > This was the formula I was trying.
> > "*"+{ShipDtl.PartNum}+"$M"+"%A"+"$I"+"*"
> > $M is the Enter Key
> > %A I think is supposed to be the Escape Key
> > $I is the Tab Key
> > Except for the Escape function, it seems to be working. So I
tried
> a
> > barcode with just "*"+"%A"+"*" to test it and it appears to do
> > nothing. I am trying to close a dialog box on a customers
website
> > with this command. If Escape is not possible I could also
possibly
> > use Alt+F4 to close the window. I haven't gotten this far, but I
> > will also need to scan a CRTL+F if that is possible.
> > If anybody can help me with any or all of these special bar code
> > features I would greatly appreciate it.
> > Thanks,
> > Brian Stenglein
> > Clow Stamping Co.
> > T
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> > have already linked your email address to a yahoo id to enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > YAHOO! GROUPS LINKS
> > * Visit your group "vantage
> > < http://groups.yahoo.com/group/vantage> " on the web.
> > * To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com
> > <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service < http://docs.yahoo.com/info/terms/> .
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> _____
> YAHOO! GROUPS LINKS
> * Visit your group " vantage
<http://groups.yahoo.com/group/vantage> " on the web.
> vantage-unsubscribe@yahoogroups.com <mailto:vantage-
Service <http://docs.yahoo.com/info/terms/> .
> _____
