[OT] Barcodes not scanning correct
Disabled all symbologies except 39 and it started working.. Well good enough for me , thanks for the response,
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> Sounds like a firmware issue.
> -----Original Message-----
> Of Michael McWilliams
> Sent: Thursday, March 26, 2009 3:20 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: [OT] Barcodes not scanning correct
> They are new. We were using HHP Keyboard/Wedge but at the rate the guys
> bust them we went to some cheapo Unitech USB scanners. The text is
> printed below the tag and is correct. I am putting a ticket in to the
> vendor since on my PC it works fine but then from my PC I start doing
> things on our TServer & the problem comes back.
> --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@> wrote:
> > Is it the scanner or the Crystal Reports tag?
> > For troubleshooting, I suggest temporarily changing the font to Arial
> or
> > something normal on that barcode text field within Crystal Reports to
> > see the literal output of the barcode.
> > However, my initial guess is that it's your hardware. If you take
> that
> > tag and use another barcode scanner, does it yield the same result?
> Is
> > this evident with every barcode scanner on your shop floor?
> > What type of scanners? USB tethered or are you using wireless
> handheld
> > scanners?
> > Vic
> Behalf
> > Sent: Thursday, March 26, 2009 3:02 PM
> > Subject: [Vantage] [OT] Barcodes not scanning correct
> > I have a barcoded tag for out Lots. On some computers when I scan
> the
> > first 1 sometimes takes as an ! and sometimes a 1.
> > Ex. R1001875-1 will come up R!001875-1 a couple times and then scan
> > correct a couple. I have never seen this one before, any ideas.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> have already linked your email address to a yahoo id to enable access. )
I have a barcoded tag for out Lots. On some computers when I scan the first 1 sometimes takes as an ! and sometimes a 1.
Ex. R1001875-1 will come up R!001875-1 a couple times and then scan correct a couple. I have never seen this one before, any ideas.
For troubleshooting, I suggest temporarily changing the font to Arial or
However, my initial guess is that it's your hardware. If you take that
tag and use another barcode scanner, does it yield the same result? Is
What type of scanners? USB tethered or are you using wireless handheld
scanners?
Vic
They are new. We were using HHP Keyboard/Wedge but at the rate the guys bust them we went to some cheapo Unitech USB scanners. The text is printed below the tag and is correct. I am putting a ticket in to the vendor since on my PC it works fine but then from my PC I start doing things on our TServer & the problem comes back.
> scanners?
> Vic
or
that
Is
handheld
> scanners?
> Vic
Behalf
the
