Well, it looks like I can't send you my word file. If you send me your
email address I will send it to you off line.
Of Dale R. Kalsow
Sent: Monday, April 21, 2008 1:43 PM
Subject: RE: [Vantage] OT kind of.... SQL ODBC connection problem
Looks like it stripped of the attachment. Let's try that again. :^)
Setup Instructions for FRx 6.7
Behalf
Of Dale R. Kalsow
Sent: Monday, April 21, 2008 1:37 PM
Here are my instructions for FRx. I hope they help J
Behalf
Of Norman Hutchins
Sent: Monday, April 21, 2008 1:22 PM
Subject: [Vantage] OT kind of.... SQL ODBC connection problem
I'm trying to set up a ODBC connection to our SQL server for FRx, when I
do
I get the errors below. FYI, these connects work fine from the server,
so it
must be a remote connection problem. I have checked a bunch of the
settings
on the server and can't solve it.
http://images.devshed.com/fds/smilies/banghead.gif
If I use the SQL Server 2005 Native Client Driver the following error
occurs:
Microsoft SQL Server Login
Connection failed:
SQLState: '08S01'
SQL Server Error: 233
[Microsoft][SQL Native Client]Named Pipes Provider: No process is on the
other end of the pipe.
Connection failed:
SQLState: '08S01'
[Microsoft][SQL Native Client]Communication link failure
Connection failed:
SQLState: '08001'
SQL Server Error: 0
[Microsoft][SQL Native Client]An error has occurred while establishing a
connection to the server. When connecting to SQL Server 2005, this
failure
may be caused by the fact that under the default settings SQL Server
does
not allow remote connections.
OK
If I use the SQL Server 2000 Driver the following error occurs:
Connection failed:
SQLState: '01000'
[Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen
(PreLoginHandshake()).
Connection failed:
SQLState: '08001'
SQL Server Error: 11
[Microsoft][ODBC SQL Server Driver][DBNETLIB]General network error.
Check
your network documentation.
OK
Any help would be greatly appreciated.
http://images.devshed.com/fds/smilies/honorhim.gif
Norman
Of Dale R. Kalsow
Behalf
Of Dale R. Kalsow
Behalf
Of Norman Hutchins
do
so it
settings
occurs:
Connection failed:
SQLState: '08S01'
Connection failed:
SQLState: '08S01'
Connection failed:
SQLState: '08001'
SQL Server Error: 0
failure
does
OK
Connection failed:
SQLState: '01000'
Connection failed:
SQLState: '08001'
Check
OK
Norman
