[OT] Spool32 printing problems
I installed some new network printers and experienced the same error
occasionally after that on Win98se machines only. I fould a
suggestion on another website to replace the spoolss.dll with the
spoolss.dll from WinME. I had five machines with errors before the
file switch and zero after.
Make sure to rename your Win98 spoolss.dll before overwriting it. :~)
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...> wrote:
> I have long running and persistent problems with PCs printing via
other PCs and getting Spool32 errors in Kernel32.dll (Windows
98se). I see these every so often on a PC (all others work fine)
but it seems like once it starts happening it has nothing but
trouble printing. Once it has the spool32 issue it won't print
again until it has been booted. Also, if you look in the printers
list after an error no printers are listed.
> I have double checked the drivers and even reinstalled on occasion
but nothing seems to help. Even reloaded Windows-98 but it still
happens at least 4-5 times a day. Only common thread seems to be
that it errors out most often when printing thru another PC that is
sharing a printer. Possible mismatch in version of spool32?
> Any ideas what to try next would be appreciated. Eventually I'll
get us all to Win2K but not before the end of the year and in the
shop (where current problem PC is) last.
> Thanks,
> Todd Caughey
> Harvey Vogel Mfg. Co.
I have long running and persistent problems with PCs printing via other PCs and getting Spool32 errors in Kernel32.dll (Windows 98se). I see these every so often on a PC (all others work fine) but it seems like once it starts happening it has nothing but trouble printing. Once it has the spool32 issue it won't print again until it has been booted. Also, if you look in the printers list after an error no printers are listed.
I have double checked the drivers and even reinstalled on occasion but nothing seems to help. Even reloaded Windows-98 but it still happens at least 4-5 times a day. Only common thread seems to be that it errors out most often when printing thru another PC that is sharing a printer. Possible mismatch in version of spool32?
Any ideas what to try next would be appreciated. Eventually I'll get us all to Win2K but not before the end of the year and in the shop (where current problem PC is) last.
Todd Caughey
Sorry to be the bearer of bad tidings but I never got this problem fixed on
a Win98se machine. Started when we added the 5.2 client for training
purposes to PC that were on 5.1. Re-installing things helped but the
problem resurfaced over time. I finally upgraded to XP. I tried every
suggestion I could get from the list and nothing helped in the long run so I
bit the bullet and upgraded.
Mitchell Kirby
Riten Industries, Inc.
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
Sent: Thursday, April 08, 2004 3:21 PM
Subject: [Vantage] [OT] Spool32 printing problems
Todd Caughey
Yahoo! Groups Links
> Thanks,
> Todd Caughey
