OT-Windows automatic updates on XP
If you turn Auto on you will get SP2 unless you use the MS utility that
prevents it.
And that is only good for a few more weeks.
If you use Active Directory you can turn off / on updating by using
profiles.
I would use the custom update feature instead of the Express Install.
It gives you more control over what is installed and you can install updates
other then SP2.
I have been doing that today myself.
Also check out HFNetChkPro, very helpful for updating.
There are other good programs for mass updating as well.
Jim Moore
Sent: Friday, October 15, 2004 11:15 AM
Subject: [Vantage] OT-Windows automatic updates on XP
When XP-SP2 came out, I turned off all of the automatic updates on
our user workstations until I could see how things would turn out.
Currently, when I setup a new XP(pro) workstation, and I go to MS
site to update windows, it now gives you the option of an 'Express
Install', which is what I have been using. Knowing that I do not
want to update to SP2 quite yet:
1) Is the 'Express Install' all I really need to use?
2) If I turn 'Automatic updates' on again, will I get just
new 'Express' files, or all, or SP2?
How do you guys do yours?
I have another question. Sometimes when I have a question for the
group, I will try to 'search archive' first, but have little to no
luck unless it has been posted very recently. Any suggestions on
how to search better?
Thanks!
Ann Rohyans
AMFAB
Thanks!
Ann Rohyans
AMFAB
