Out of disk space while using Epicor
Hello to all,
This week I came accross an error during my use of Epicor. all my local c: drive was used, so forms could not open. Mind you I had a few already opened… :wink:
Looking at the hiarchy of files using a nice tool Wiztree, I found out where was my most usage. I found out that under my C:\Users\PierreH\AppData\Roaming\epicor\log there was a ton of files named TraceDataxxx.txt.
145 GB of them… since 2015, when we went live…
I did not realize to not forget to delete them after use when I am tracing a process… But I think there is a bit flag that I need to set to off and it is the first one (Enable trace logging) which was turned on…(thus the 145GB… )
So I thought it was a good idea to write this so users can be warned to disable this feature after use !
Have a great day!
Pierre
That’s awesome Pierre, you are a tracing legend!
Dats a lot of logs.
similar problem i found but on the server manager log files was filled with more than 200GB from process tasks, so i had to create a powerShell script to clear it on weekly bases leaving two weeks of data (ONLY) just in case we want to investigate any failed or error tasks.
This one appeared to work.
Define the path to the log files
$logPath = “C:\Path\To\LogFiles”
Get the current date
$currentDate = Get-Date
Define the retention period (14 days)
$retentionPeriod = 14
Get all log files in the directory
$logFiles = Get-ChildItem -Path $logPath -Filter *.log
Loop through each log file
foreach ($file in $logFiles) {
# Calculate the file’s age
$fileAge = $currentDate - $file.CreationTime
# Check if the file is older than the retention period
if ($fileAge.Days -gt $retentionPeriod) {
    # Delete the file
    Remove-Item -Path $file.FullName -Force
Output a message indicating the cleanup is complete
Write-Output “Log file cleanup complete. Files older than $retentionPeriod days have been deleted.”
