Jasper,
Hope these help.
Gil Amilbangsa
Australian Healthcare Equipment - Murphy Furniture
gil.amilbangsa@...
First question:
If you have a job for a STOCK part and the part consist of a few sub-assemblies, how would you handle making an overrun of the sub-assemblies? How would you get them back into inventory in the middle of the job so the overrun does not have to go through the whole job process?
[Gil Amilbangsa] You can use the auto-receive feature or receive manually to inventory if the assembly is a part master item. If the assembly BOM has the last operation ticked as auto-receive to inventory, any over-runs for the job will be posted to inventory automatically. Otherwise, you can receive the sub-assembly to inventory using the Receipts from Manufacturing screen. Vantage help explains this in more detail.
Second question:
We have a situation were we have a large bar stock. The first operation of a job requires 10 pieces cut from this bar stock. Instead of putting the remaining bar stock back on the shelf, they decide to cut the rest of the stock yielding 15 pieces. The bar stock has only one part number associated with it. How could we handle the overrun? It's not really bar stock anymore because it's been cut. Do we need to create a new part number for these pieces and make this operation a separate job? How could we get those pieces to show up in inventory so we know we have them.
[Gil Amilbangsa] Similar situation as above. You need to add the cut bar in the Part Master and add it as a sub-assembly in the parent part BOM. You can then receive any excess to inventory. No need to create a separate job for it. The next time you raise an order for the parent part, check the cut bar sub-assembly in the Job BOM. The available stock qty will be displayed. You then have the option to pull from invenotry or make new cut bars direct to the job.
Any insight would be appreciated.
Jasper
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=1705007183:HM/A=1663535/R=0/SIG=11ps6rfef/*http://www.ediets.com/start.cfm?code=30504&media=atkins> click here
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmail/S=:HM/A=1663535/rand=312163783>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Hope these help.
Gil Amilbangsa
gil.amilbangsa@...
First question:
Second question:
Jasper
ADVERTISEMENT
