jdtrent
(Joe D Trent)
October 22, 2024, 9:21pm
1
Hey,
I’ve seen where I can override the form onload event. I’m in a dashboard where the on load event fires that dang slider and I want it to stop.
So, I added this event to override the form onload event, but it’s not firing. The slider is still showing up, and the dialog show I put in the slider-open slot isn’t firing.
Reckon what I missed?
Joe
jdtrent
(Joe D Trent)
October 23, 2024, 2:19am
2
With the override event set as above, I get this in the debug:
main.f970e717b4861fde.js:160 view loaded Ice.UIDbd.TeamLeaderAssembly
18[Violation] Added non-passive event listener to a scroll-blocking <some> event. Consider marking event handler as 'passive' to make the page more responsive. See <URL>
5[Violation] 'requestAnimationFrame' handler took <N>ms
main.f970e717b4861fde.js:160 application initialized
main.f970e717b4861fde.js:160 event: Form_OnLoad actions: [event-next, event-next, condition]
main.f970e717b4861fde.js:160 action: event-next
main.f970e717b4861fde.js:160 event: BeforeInitialize actions: [condition]
main.f970e717b4861fde.js:160 action: condition param: {expression: 'true', onSuccess: Array(1)}
main.f970e717b4861fde.js:160 event: btn_search_v97078ReviewShopLoadStart_0_0 actions: [condition]
main.f970e717b4861fde.js:160 action: condition param: {expression: 'true', onSuccess: Array(2)}
main.f970e717b4861fde.js:160 action: slider-open param: {page: 'v97078ReviewShopLoadStart_0_2'}
[Violation] Forced reflow while executing JavaScript took 62ms
[Violation] Forced reflow while executing JavaScript took 240ms
main.f970e717b4861fde.js:160 (2) ['rowChanged event started for v97078ReviewShopLoadStart_0_0', Array(1)]
main.f970e717b4861fde.js:160 rowChanged: v97078ReviewShopLoadStart_0_0_RowChanged actions: [condition]
main.f970e717b4861fde.js:160 action: row-update param: [{…}]
main.f970e717b4861fde.js:160 {v97078ReviewShopLoadStart_0_0.JobOper_JobNum} ===> 037190-1-1
main.f970e717b4861fde.js:160 {v97078ReviewShopLoadStart_0_0.JobOper_AssemblySeq} ===> 0
main.f970e717b4861fde.js:160 {v97078ReviewShopLoadStart_0_0.JobOper_OprSeq} ===> 10
main.f970e717b4861fde.js:160 (2) ['rowChanged event completed for v97078ReviewShopLoadStart_0_0', Array(2)]
[Violation] Forced reflow while executing JavaScript took 469ms
17[Violation] 'setTimeout' handler took <N>ms
The override of Form_Onload never appears.
I also tried a "before form onload like this:
Debug spit this out:
20[Violation] Added non-passive event listener to a scroll-blocking <some> event. Consider marking event handler as 'passive' to make the page more responsive. See <URL>
10[Violation] 'requestAnimationFrame' handler took <N>ms
main.f970e717b4861fde.js:160 event: Form_OnLoad_Override actions: [event-next, event-next, condition]
26[Violation] 'setTimeout' handler took <N>ms
main.f970e717b4861fde.js:160 event: SysInitTransView actions: [row-update]
main.f970e717b4861fde.js:160 %dashboardFilters% ===> %dashboardFilters%
main.f970e717b4861fde.js:160 action: condition param: {expression: '{TransView.SysDashboardFilters} === true', onSuccess: Array(2)}
main.f970e717b4861fde.js:160 {TransView.SysDashboardFilters} === true ===> false === true
It still fired the slider.
I tried an after Form_Onload event and added a slider-close, but got no closing of the slider. A dialog-show by itself on the after form load event did show the dialog box after I clicked the slider closed.
Grasping now. I just want that slider not to open. Grr.
Joe
aarong
(Aaron Gulley)
October 23, 2024, 7:56am
3
Rename the sliderpage to something like xxxBlahblah it won’t fire. You can then use the SysInit event to fire whatever you want
jdtrent
(Joe D Trent)
October 23, 2024, 1:30pm
6
I’ve tried renaming the slider, but the refresh and overflow menu disappear when I do:
It’s always something.
Joe
hmwillett
(Hannah Willett)
October 23, 2024, 1:36pm
7
This is actually a known thing. Happens with deleting and renaming.
****** Huge caveat that I found doing this… If you delete that slide out, it will also delete/remove/hide/whatever the overflow menu that allows you to access App Studio. Super annoying, but not world ending as you can add /designer/pages to the URL before the question mark.
^ If you want to leave it that way.
My brain isn’t fully awake for your original question yet.
HannahLoading.exe
aarong
(Aaron Gulley)
October 23, 2024, 1:41pm
8
Yep, I found this as well. It’s shit but it’s a workaround…
hmwillett
(Hannah Willett)
October 23, 2024, 2:01pm
9
Oh–okay. So this whole slider thing is a bit of red herring. You’re overriding the event, but I’m going to wager that slider isn’t the one being shown.
Your BAQ has a parameter, yeah? That will always fire, slider or no. The easiest way is to nix the params and change your BAQ to use filters instead which can be sent using the provider model.
hmwillett
(Hannah Willett)
October 23, 2024, 2:55pm
10
jdtrent
(Joe D Trent)
October 23, 2024, 4:46pm
11
Ah, I hadn’t tried the BAQ yet (I’m not the author, just doing the uplift). I’ll check to see if there’s a parameter. There is a tracker on the dashboard, though.
Joe
jdtrent
(Joe D Trent)
October 23, 2024, 9:33pm
13
No parameters. I’m just going to copy the dashboard and delete the trackers so it won’t do that. I hope.
Joe
hmwillett
(Hannah Willett)
October 23, 2024, 9:35pm
14
What’s the slider look like?
What’s it say at the top? Does it match your tracker fields?
It’s possible there’s an initialize event for them that’s popping it open too.
jdtrent
(Joe D Trent)
October 24, 2024, 8:51am
15
The slider had the same title as the tracker on the old form.
I deleted all the trackers (in a copy of the dashboard), deployed, and created new trackers in a panel card on the main form (like your example). Works great!
Joe
