>Great idea Ami. The configurator can change the method of manufacturing based
> No. How would that help?
on rules. You could create a rule with the quantities that will change the
number of boxes and the amount of time as needed.
Mark W.
>We
> There is some talk around here about adding an operation for
> packaging onto all of the Jobs that go through here.
> We might also look at treating boxes as a raw material.
> There are some pro's and con's for doing each.
> 1 of the pro's is that we could more accurately track our costs.
> could also keep track of how shipping clerks are spending theirof
> time. Some hope that it will help with scheduling, but since much
> our shipping is Kanban or JIT related it really won't help thatmuch.
> I'm just curious if anyone else is doing this or has contemplated
> doing this.
> Is it a good idea or not?
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
>We
> doing this.
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
--- In vantage@yahoogroups.com, "Neil Christie" <nchristie@...> wrote:
> In three places, I have implemented packaging material (boxes,
> inserts, labels) as controlled part numbers. For special inserts
> (i.e., instapak molded foam made in custom molds), the instapak
tool
> and the mold/insert is a tool on the router as well.
> - better cost info
> - better packaging people time info
> - capacity planning (very, very minor - maybe just interesting, but
> not useful)
> - design control of packaging
> - where we've been smart (not all the time), a reduction in the
> total inventory because we use more common boxes, and can see in
> inventory when we're getting low
> A risk - service orders will use boxes but if you (we) forget to
put
> them on the service order, your cycle counts will be way off.
> Just my 2 cents.
> Neil
> --- In vantage@yahoogroups.com, "Brian Stenglein" <bstenglein@>
> We
much
> of
> much.
> > doing this.
> > Thanks,
> > Brian Stenglein
> > Clow Stamping Co.
>tool
> and the mold/insert is a tool on the router as well.put
> - better cost info
> not useful)
> them on the service order, your cycle counts will be way off.Stenglein" <bstenglein@>
> Just my 2 cents.
> Neil
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Brian
> wrote:much
> We
> of[Non-text portions of this message have been removed]
> much.
> > doing this.
> > Thanks,
> > Brian Stenglein
> > Clow Stamping Co.
>a
> Thanks to those who have replied. I have a follow up question for
> any of you. I think the big dilemma I see is that there is quite
> bit of variability in order qty's which will throw off productionminutes
> stds and box sizes & qtys.
> Example, a part gets ordered 1 time for 250 pcs, it takes 20
> to "bulk pack" and uses 1 10X8X6 box, it weighs 24 pounds. Thenext
> time the customer orders 500pcs. If left alone the job would sayof
> that it should take 40 minutes and use 2 10X8X6 boxes, but in
> actuality, since 500 pcs is under a 50 lbs weight limit that most
> our customers have, we could put all 500 in 1 bigger box. Sincethe
> parts are bulk packed, there is no extra time involved in thelarger
> qty. If they were layer packed instead of bulk packed the extratime
> would be needed.
> This is a simple example but could happen on a larger scale also.
> Any suggestions on how to deal with this kind of variability?
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
> A risk - service orders will use boxes but if you (we) forget to put
> Just my 2 cents.
> Neil
--- In vantage@yahoogroups.com, "ami_miker" <mrandolph@...> wrote:
> Brian,
> Does Clow Stamping use a configurator?
> Michael Randolph
> Infinity Business Consulting
> mrandolph@...
for
> a
> minutes
> next
> of
> the
> larger
> time
> > would be needed.
also.
> > Thanks,
> > Brian Stenglein
> > Clow Stamping Co.
