PackSlip Label changing based on CustID
Hello~!
I was wondering if there was a way in SSRS report builders to show/hide certain fields based on the CustID, so that when a shipper prints a Label or Both, the label attached to that specific CustID prints.
Thank you.
Yes, in the properties for the field you will see a ‘Visibility’ section:
You can use the Show or Hide Based on an Expression section.
I do not believe CustID is in the base dataset but CustNum is.
