Panel Card Stack Issue on Tab Pages
I have a dashboard I am trying to create that aggregates a lot of data from many different BAQ’s. I have a main page and a couple lower level tab pages as shown.
I am trying to create a panel card stack of panel card grids on one of the pages and am running into some strange behavior. When I create the panel card grids and then stack them, I get the stack as expected but am still seeing the grids separately as well.
Here is the Jobs data page in design - you see a jobs list grid and the a panel card stack with Job Assignments and Job Labor Budgets (two panel card grids in a panel card stack)
When I preview the dashboard, I get the Job list as expected, I also get the panel card stack as expected showing the two data grids but I also get the two panel card grids separate after the stack.
When I scroll down, I could see the separate Job Labor Budget grid as well.
This has perplexed me for a while and I am struggling to figure out what is causing this. I have done many dashboards with panel card stacks on the main page and have not seen this issue before.
What am I missing?
Hi @eandres, i added empty grids in stack and then added BAQ’s it worked for me.
The issue I’m currently facing is that when I switch to other tabs and then come back to the Panel Card Stack, the tab name does not update.
epicor kinetic-2024-2 #applicationStudio help
Hi Ed, did you ever figure out what the solution for this is? I’m running into the same issue adding a panel card stack to MES.
I have not found a solution. I plan to start over with the dashboard when we get to version 2025.2.10 and see if I can get it to work. It is frustrating that something that should be easy to do is made to be so difficult.
