We are currently on 6.1 and moving toward 8.03 upgrade. We are looking at our processes as we make the upgrade and one item that was brought up was to have electronic routing to avoid having to hold paper copies for our current 12 year requirement. I know we could scan in the completed routing once the job is closed but we were wondering if anyone is using an online routing that the shop operators would access via PC to enter any information required for the operation they are working on? Are current paper routings are set up to prompt the operators to fill in certain data associated with the operation they are working on.
We would appreciate any input.
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 1114
Fax: 262-252-4974
Email: paul.pachniak@...
Web: http://www.aceprecision.com/
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
Paul E. Pachniak
Accounting Manager
Fax: 262-252-4974
