Part Maintenance: warehouse issue on part
hi Folks
we have an issue where someone on part setup has added a warehouse to a site, which it does not belong.
this is now skewing available stock figures at the site
there seems to be no way to remove this link, as it has been transacted on.
anyone encounter this and get a fix beyond a new part setup?
mal
This is potentially a good “Idea” you could submit, if nobody provides a known solution.
You can add a warehouse to a part/site, but once transacted against, you can’t delete it. It would be nice to have an “inactive” boolean option to prevent someone from being able to receive/transfer parts to an inactive warehouse (per part).
Are you trying to fix it so this part doesn’t go to this warehouse any longer? The existing inventory is removed from it and placed in the correct warehouse? I am trying to figure out what part of the link you would like to remove. The part could be quantity adjusted out of the wrong warehouse and on the sites area of the part the primary warehouse and primary bins can be changed I believe.
our main manufacturing site has been added as a warehouse to site X
so when site X have zero stock, it still looks like the site has access to all the stock in the manufacturing site - hence no MRP transfer orders autogenerated from MRP
make sense?
So is the main manufacturing site considered a shared warehouse on the site config tab. If so it can be removed.
no its not setup as a shared Warehouse
this has been done on part level only
