Part Tracker Revision list sorting
Hi folks,
When using Part Tracker, under the Revision list tab my default selected row is not correct. I’d like to be able to configure/sort. I understand it sorts by effective date by default. I’ve attempted to write a BPM post processing for Part.GetbyID and try and filter by approved only but failed. If you look in this screenshot it selects Rev 17 since that comes before 18, but overall I’m lost on having the Revision list pick the row with an approved Rev, Effective date DESC. Does this have to do with the Process Mode being set to Sequential? I’d prefer to not have to create a BAQ nor do I understand much C# expressions.
Hi
I think you can add a grid filter, filter, then save layout
Hi Jarry,
This worked for my own Personalization but when I’m in Developer mode and go into another employees personalization and add the filter and save it doesn’t save the changes. How could I force a personalization on all of the users? Menu Maintenance?
it is in security account, allow personalization, but for each account, you have to do the filter manipulation.
