Part Update with Service Connect
Thanks, Brian. I'm a super noob at Service Connect (obviously). Can you explain the basic steps to setup the call to part.getbyID? You can email me if you prefer... cjohnsonATquestaircraftDOTcom.
Thanks very much!
Cari
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> Off the top of my head, I remember that when doing a Part Update, you need to set the CompanyID at the top of the UpdateRequest dataset, and then set Company, PartNum, and PartDescription in the Part sub-dataset.
> At least as I recall, I didn't get what I expected unless I set PartDescription, which meant that typically I would call Part.GetByID() based on the input PartNum, then do my update with the description that I got back.
> Your mileage may vary. This is in 8.03.405.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of links0330
> Sent: Wednesday, June 10, 2009 2:01 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Part Update with Service Connect
> Thanks. That was easy enough, but now that I've updated the rowmod to U, I get an error in the workflow that says, "An Entry With the Same Key Already Exists."
> My workflow is just one conversion and a web method using update.part. When I ran a trace I saw it use a checkpartchanges method, so I have tried running a workflow that also has a conversion and web method for that. However, in either one I get the error message above, so I thought I'd go back to the simple one to troubleshoot.
> Thanks for your help.
> Cari
> --- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@> wrote:
> > In your conversion before the update method under configuration within
> > the dta section under part node right click the rowmod and select set
> > literal value enter U
> > Rob Bucek
> > Manufacturing Engineer
> > PH: 715-284-5376 ext 311
> > FAX: 715-284-4084
> > <http://www.dsmfg.com/>
> > (Click the logo to view our site)
> > ________________________________
> > Of links0330
> > Sent: Wednesday, June 10, 2009 9:47 AM
> > Hmmm, no I didn't. Can you tell me specifically where to set it?
> > Thanks!
> > Cari
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > "bw2868bond" <bwalker@> wrote:
> > > Did you set the RowMod field in the DataSet to U before the update
> > method is called?
> > "links0330" <cjohnson@> wrote:
> > > > I've created a basic workflow with Service Connect to update a part
> > record. For test purposes, I'm just trying to update the description of
> > one part. The workflow runs successfully with no errors, but the updated
> > description does not show on the part record in Vantage. Any help?
> > > > My ultimate goal is to create and update primary bin locations for
> > about 2000 parts, which I noticed has been discussed in this forum
> > before. If anyone has a sample workflow or any help on that, I'd
> > appreciate it.
> > > > Thank you,
> > > > Cari Johnson
> > > > Quest Aircraft
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
I've created a basic workflow with Service Connect to update a part record. For test purposes, I'm just trying to update the description of one part. The workflow runs successfully with no errors, but the updated description does not show on the part record in Vantage. Any help?
My ultimate goal is to create and update primary bin locations for about 2000 parts, which I noticed has been discussed in this forum before. If anyone has a sample workflow or any help on that, I'd appreciate it.
Thank you,
Cari Johnson
Quest Aircraft
Did you set the RowMod field in the DataSet to U before the update method is called?
> Thank you,
> Cari Johnson
> Quest Aircraft
Describe the elements and the order they are in within your work flow
Rob Bucek
FAX: 715-284-4084
Of links0330
Sent: Tuesday, June 09, 2009 7:09 PM
Subject: [Vantage] Part Update with Service Connect
Thank you,
Cari Johnson
Quest Aircraft
Thanks!
Cari
> > Thank you,
> > Cari Johnson
> > Quest Aircraft
Rob Bucek
FAX: 715-284-4084
Of links0330
Thanks!
Cari
method is called?
appreciate it.
> > Thank you,
> > Cari Johnson
> > Quest Aircraft
Cari
> Rob Bucek
> FAX: 715-284-4084
> Of links0330
> Thanks!
> Cari
> method is called?
> appreciate it.
> > > Thank you,
> > > Cari Johnson
> > > Quest Aircraft
-bws
Cari
> Rob Bucek
> FAX: 715-284-4084
> Of links0330
> Thanks!
> Cari
> method is called?
> appreciate it.
> > > Thank you,
> > > Cari Johnson
> > > Quest Aircraft
