Hello! We have a custom dashboard that pulls parts from Part along with other information and it has worked every single time with every single part that has an approved revision except for one specific part. This part is successfully pulled in every other spot in Epicor. Name is 2242-12-12S. It’s not like there’s an invalid character in the name. Any suggestions?
I ran into an issue recently with the “Part On Hand Status” dashboard, as well as, customizations I have on Part Transaction History, Time Phased Inquiry that use a BAQ - where some part numbers were not recognized due to the format being treated as a date. This may be your issue. I have an open case (CS0005559079) with support that seems to just be sitting
I did find a couple of other posts with part number as date issues so this is not new. Also, per AI…
If you are seeing Epicor part numbers unexpectedly formatted or changing into dates, this is a known bug in Epicor Kinetic and Application Studio. It happens because the system uses Newtonsoft JSON framework via REST API, which automatically tries to convert string-based fields that look like ISO standard dates into actual dates
I appreciate the help. Seems like that could be the issue based on all these people having similar issues, except we have another part without a letter in it named 03-06-2242 and that loads fine but that is definitely still a possibility. I have opened my own ticket with Epicor so hopefully someone can help and it won’t come to a sitting like yours .
