I’m trying to locate where I can change the Subcontract Days Out field.
Right now the default for this field is 0 so we have to manually the Days Out for different subcontract vendors. Please help me locate the source where this data got pulled from.
I tried look into Supplier Price List but the problem is, we need full price lists and it has to be done on a part by part basis. So basically, if we’re routing a new part, it still won’t pull the default days out because the new part isn’t on a price list yet…
Any insight would be greatly appreciated. Thank you!
As far as I know, the only out-of-the-box solution is the Supplier Price List (on the Subcontract Operations > Price Breaks > Detail sheet)… as that is the only place where Suppliers and Parts are linked.
The other option would be to create a customization using UD fields on either the Part or Supplier table or a UD table.
The 2 places that the application looks at are the Supplier Price List Lead Days field (for both parent part and selected operation) and at the Subcontract Operations Detail screen.
Hi Jason!
Thank you for the great Welcome.
It has been a while since you and have worked on a case.
I am so looking forward to the questions and responses on here.
What a great learning and communication hub.
