Parts Missing ABC Code, Part Cycle Count Status standard SSRS report print out error
Hi guys,
Getting a weird behavior of a new environment that just recently installed, version is 10.2.300.6. Going through a testing process currently and found that when trying to print a preview of Parts Missing ABC Code, Part Cycle Count Status standard SSRS reports getting an error: (Object reference not set to an instance of an object.) Did anyone get something similar before? Any advice would be very much appreciated. Thanks!
Stack Trace for this one:
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: Object reference not set to an instance of an object.
Stack Trace:
at Erp.Internal.IM.CCMissingABC.doWarehseCalculations(Warehse b_whse) in C:_projects\ERP\RL10.2.300.0\Source\Server\Internal\IM\CCMissingABC\CCMissingABC.cs:line 236
at Erp.Internal.IM.CCMissingABC.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:_projects\ERP\RL10.2.300.0\Source\Server\Internal\IM\CCMissingABC\CCMissingABC.cs:line 132
at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:_Releases\ICE\ICE3.2.300.6\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 44
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_Releases\ICE\ICE3.2.300.6\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 93
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_Releases\ICE\ICE3.2.300.6\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in c:_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in c:_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 577
Stack Trace:
at Erp.Internal.IM.CCPartStatus.doWarehseCalculations() in C:_projects\ERP\RL10.2.300.0\Source\Server\Internal\IM\CCPartStatus\CCPartStatus.cs:line 302
at Erp.Internal.IM.CCPartStatus.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:_projects\ERP\RL10.2.300.0\Source\Server\Internal\IM\CCPartStatus\CCPartStatus.cs:line 116
I’d start by placing a filter for one item. This way you can determine if it is related to a specific record or a global phenomenon.
You could also hunt for errant data (like was a WH or Plant deleted). It seems that func does this in a nutshell:
Gets all PartWH records based on passed whCode. SystemAbc must = ā€œā€
Iterates over PartWH records
Get last PartTran
Get Last Plant record (based on company and PartWH.plant)
starts build a temp table of the results (ttPartMissing)
Nothing obvious sticks out.
Hi Chris,
Thanks for your advice. Actually, filtering minimized an area of investigation. We found that problem was related to a particular Warehouse and moreover another company. That company used rarely so we do not really paid too much attention to that. It also ended up with an interesting thing. We fixed it by writing a query to check on some parts and found that some parts were entered incorrectly. There were multiple spaces in a PartNum. After we removed them it worked as expected.
