PartWhse.onhandqty BAQ Cal Field
Thank you guys. i will def include as much parenthesis as possible going forward. thanks a lot!!!!!
Jose
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> When I create a calculated field, I find its best to go crazy with the parentheses. Also, I think you need an else statement, so try this:
> ÂÂ
> total((if (partwhse.warehousecode = 'XX') then (partwhse.onhandqty) ELSE (0)))
> ÂÂ
> From: neverunmacron <neverunmacron@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, March 21, 2013 3:17 PM
> Subject: [Vantage] PartWhse.onhandqty BAQ Cal Field
> ÂÂ
> hello
> i am trying to create a column that shows me the total onhandqty for one of my warehouses. I currently have one column with as a calculate field because the partwarehouse is a summarized table.
> In my column where i show all onhandqty the formula is Total(Partwhse.onhandqty)
> i have tried total(if partwhse.warehousecode = 'XX' then partwhse.onhandqty) and got a syntax error. i also tried total(find partwhse.onhandqty where partwhse.warehousecode = 'XX' and i keep getting syntax error.
> any help?
hello
any help?
Good Day Neverunmacron:
See below.
Len
Of neverunmacron
Sent: Thursday, March 21, 2013 3:18 PM
hello
partwhse.onhandqty Else 0) and got a syntax error. i also tried
any help?
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Â
Â
Â
hello
any help?
