Passing a String for Key1-GetByID for a UD Table
Thanks Rob- that first parameter is causing my pain, if I pass a 'converted from DateTime' string, properly formatted, it bombs. If I pass an 'assigned' string ( ie: string newdate = "01/01/2014"), no problems.
This is my conversion code:
string NewDueDateString = NewReqDate.ToString("MM/dd/yyyy");
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Friday, May 24, 2013 8:45 AM
Subject: RE: [Vantage] Passing a String for Key1-GetByID for a UD Table
Â
Correct sir, it was declared previously, I just didn’t include that snipet
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Bill Jackson
Sent: Thursday, May 23, 2013 4:03 PM
Subject: Re: [Vantage] Passing a String for Key1-GetByID for a UD Table
Rob:
I'm guessing that your variable 'intDMRNum' is actually a string ?
From: Rob Bucek <rbucek@...<mailto:rbucek%40dsmfg.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Thursday, May 23, 2013 4:43 PM
This isn't the only way to do it im sure but here is how ive run that in the past....
Dim adaptUD19 As UD19Adapter = New UD19Adapter(JobClosingForm)
adaptUD19.BOConnect()
Try
Dim recUD19 As Boolean = adaptUD19.GetByID(intDMRNum,intActnNum,"","","")
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Bill Jackson
Sent: Thursday, May 23, 2013 3:24 PM
Subject: [Vantage] Passing a String for Key1-GetByID for a UD Table
Hi Folks,
on Epicor 9.04.507A
In a customization, I'm trying to check on the existence of a record in our 'UD10' Table (we use key1 for Holidays, ie: 12/25/2013).
In a method within the customization, I pass the OrderRel.Reqdate:
Using the UD10 Adaptor, I convert this DateTime variable:
code:
UD10Adapter adUD10 = new UD10Adapter(oTrans);
adUD10.BOConnect();
If I message it out, I verify that my string reads correctly (ie: "12/25/2013")
However, this line bombs out:
code:
bool boolFound = adUD10.GetByID( NewDueDateString, String.Empty, String.Empty, String.Empty, String.Empty );
I'm guessing something about the string is causing this.
If I set a string , such as:
code:
string mydate = "12/25/2013";
bool boolFound = adUD10.GetByID( mydate, String.Empty, String.Empty, String.Empty, String.Empty );
Works fine-I've tried manipulating the converted string, verified that the strings appear to be exact, etc.
just wondering fi I'm missing something simple..?,
thanks
Bill J.
Hi Folks,
 on Epicor 9.04.507A
code:
UD10Adapter adUD10 = new UD10Adapter(oTrans);Â
adUD10.BOConnect();Â Â
code:
code:
thanks
Bill J.
Try
Hi Folks,
on Epicor 9.04.507A
code:
adUD10.BOConnect();
code:
code:
thanks
Bill J.
Rob:
Â
Try
Hi Folks,
on Epicor 9.04.507A
code:
adUD10.BOConnect();
code:
code:
thanks
Bill J.
Rob:
Try
Hi Folks,
on Epicor 9.04.507A
code:
adUD10.BOConnect();
code:
code:
thanks
Bill J.
