Payroll Hours-Minutes
Thanks, everybody, this was a real DUH on my part -- DspClockInTime and
OutTime is just what I need.
Lydia
Sent: Friday, September 27, 2002 11:41 AM
Subject: [Vantage] Re: Payroll Hours-Minutes
Look at DspClockInTime and DspClockOutTime, may be what you need.
If not, how about something like...
HourHundredChar = string(HourHundred).
HourMin = substring(HourHundredChar,1,2) + ":" + string(integer
(substring(HourHundredChar,4,2)) * .6)
...I didn't test it, but it should be close.
Lonnie
--- In vantage@y..., Lydia Coffman <lcoffman@c...> wrote:
> Hi!
> Well, your testimonials about not having time clocks really helped,
now I
> have a related challenge:
> Is there a way to convert the Vantage time (in Report Builder) from
> Hours.Hundredths to Hours.Minutes? The gal who will be doing the
time
> reporting into our ADP system is used to minutes (what the time
clock says)
> instead of hundredths of hours. I've been puzzling over this for a
couple
> of days, so I thought it was time to ask the experts. I know a
simple
> calculation would work on the hundredths:minutes side, but can't
figure out
> what to do about the hours. Anybody done this already, have a hint
or think
> I should give it up?
> Thanks and happy Friday!
> Lydia
> Canyon Engineering Products
> lcoffman@c...
> 661-294-0084
Hi!
Well, your testimonials about not having time clocks really helped, now I
Hours.Hundredths to Hours.Minutes? The gal who will be doing the time
reporting into our ADP system is used to minutes (what the time clock says)
instead of hundredths of hours. I've been puzzling over this for a couple
of days, so I thought it was time to ask the experts. I know a simple
calculation would work on the hundredths:minutes side, but can't figure out
what to do about the hours. Anybody done this already, have a hint or think
Lydia
lcoffman@...
661-294-0084
Lydia,
Check out Config Maintenance, company, your company, Module Config, Job
Management config, labor/time format.
I think this changes it across the board.
Aaron Hoyt
Design Standards
Sent: Friday, September 27, 2002 2:24 PM
Subject: RE: [Vantage] Payroll Hours-Minutes
Hi!
Lydia
lcoffman@...
661-294-0084
Lonnie
> Hi!
now I
time
clock says)
couple
simple
figure out
or think
> Lydia
> lcoffman@c...
> 661-294-0084
Try:
Clock_In_Time_HH = integer(ClockInTime)
Clock_In_Time_MM = (ClockInTime - integer(ClockInTime)) * 60
Patrick
Sent: Friday, September 27, 2002 1:22 PM
Hi!
Lydia
lcoffman@...
661-294-0084
