As always, thanks Deb. We were trying to print them after posting the
payroll.
We validate payroll off of the payroll edit list so did not give it a second
thought.
Sent: Monday, August 14, 2000 2:05 PM
To: 'vantage@egroups.com'
Subject: RE: [Vantage] (PAYROLL) Printing the payroll check register in
3. 0
Dan - are your check registers printed after payroll checks are printed and
before they are
posted? That is how we capture ours. To the best of my knpowledge, we are
out of luck afterwards. A/P registers can be re-created in A/P under check
register, but not payroll.
Deb
Sent: Monday, August 14, 2000 12:57 PM
To: 'Vantage One List'
Subject: [Vantage] (PAYROLL) Printing the payroll check register in 3.0
I am in 3.0 and tried to print the payroll check register. We are currently
processing payroll in Vantage to include cutting checks. It does not matter
what period I try to print, it tells there are no payroll records available
for processing.
Any ideas?
Daniel A. Nichols
General Manager
If any part of this message is unreadable, please contact the above at
dann@...
payroll.
thought.
3. 0
before they are
Deb
for processing.
Any ideas?
Daniel A. Nichols
General Manager
dann@...
