So we have a sales order consisting of a line with a fixed amount misc charge. Then on the orderhead we have a percentage misc charge. However, this percentage misc charge does not act on the line misc charge, only the line qty*unitprice. Is there anyway to get vanilla epicor to act on the line misc charge as well?
Hi, its looks like this is the expected behaviour. This is from the Order Management Course:
- Header vs. Line Miscellaneous Charges:
Header Miscellaneous Charges apply to the entire order and are calculated based on the total order value.
Line Miscellaneous Charges are specific to individual order lines and are not included in the header-level percentage calculations by default.
Based on this I would suspect a BPM would be needed.
What version of Epicor are you running, this snip above is from E10 days…
We are on the normal cadence for cloud Kinetic. Thanks for the insight. I will head down the BPM route.
