On several occasions we’ve had to investigate performance problem in Epicor 10 (running trial balance reports, running AFR reports, doing data loads, etc).
It seems a bit hard to diagnose performance issues, considering the layered architecture. But on the very back-end in SQL Server, we can enable the SQL Profiler and view the ERP activity as it is experienced by the database.
Whenever we do this, it shocks me how many queries are being generated and sent from the application server back to the database. For a single user, it can be 1000-4000 SQL batches per second, depending on what they are doing. Most of this looks like tiny, little queries generated by LINQ and Entity Framework.
Taking one step back to the “application server” tier (and the SSRS server), it appears that the CPU and network are both quite active. It appears that this is mostly related to the chatter between the application server and the SQL database.
Can somebody please confirm if these observations sound familiar? What are best performance counters to use when troubleshooting performance in the ERP (versions 10.1.600.19 and 10.2.200.10)? Should we be looking primarily at the database or at the application server to find the true bottleneck? Or is it based on the number of network round-trips? Is there a good way in profiler to isolate the activity of one business operation from another? We have a very fast 10 Gbit connection that connects the two tiers so it doesn’t seem to me like the network should be the problem, but I suppose that is possible if the application code gets chatty enough. I realize that my questions are very broad, but it would be nice to hear how others troubleshoot and diagnose performance issues. Also, I’m wondering how severe these types of performance issues would need to get - until Epicor would be willing to take a support case and work on a software fix.
