So far with us, personalization hasn't been a problem, they've been
able to move things to suit their needs and keeps them happy and
keeps them from griping to me. So unless you have an employee who
prefers to spend time "playing" instead of working, I find this
feature beneficial.
Barbara Kite
feature beneficial.
Barbara Kite
--- In vantage@yahoogroups.com, Charles Carden <ccarden@...> wrote:
> If you want less complaints from the users I would recommend giving
them
> that authority. There are a lot of settings that can be done to aid
> them in their job, especially when it comes to the order of fields
in
> grids. Without allowing personalizations you will find the users
> constantly moving fields around to see what they need to see. This
is
> wasted time. They should only need to do this once and save the
> layouts.
> I have not had anyone abuse the right. Most of my users are just
> concerned about making the software more usable. If you find
someone
> that is spending a lot of time changing colors, etc. instead of
working,
> you can always take the rights away from that individual.
Behalf
> Of ahmeterispaha
> Sent: Friday, June 27, 2008 7:18 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Personalization - Who needs it anyway?
> I was hoping to get more folks to weigh in on Personalization. Do
> you recommend not using it? If so why?
> Thanks,
> Ahmet Erispaha
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Mark Wonsil" <mark_wonsil@> wrote:
> > > Then do yourself a favor and disable user personalization. If
> these fields
> > > are that important, customize the app so they are available to
> all and
> > > control access via your user security rights roles.
> > Starting with 8.03.4xx, you can also go to System Management |
> Utilities |
> > Customization/Personalization Maintenance and delete
> personalizations or
> > customizations without going into the command as the user or
> through the
> > Customization route.
> > Mark W.
