Hello everyone,
we have created an idea, but didn’t got to much votes on that and we would be happy if some of you maybe will vote for this:
Kinetic view personalization to able to save | Epicor Ideas Portal
- KIN-I-4319
at this moment I see the fields in the table only which are in the body group and i need always to click on “full screen” (the full screen button at the bottom of the page… sometimes called the “more” button) to see more information. I would like to save this in my personalization, so next time if i open the same screen the information will be already displayed and i don’t need to click on full screen in order to see the fields which are in the extension group. There is a possibility now to save the layout as extended, which is great, but i can not see anything for full screen. check also KIN-I-4050 was highlighted as already exist after the upgrade , i have tested the webversion in additional environment after the upgrade and i still need to click on "full version " button to see the details which are on the section “extensions” as only the body fields are visible. Our suggest was to allow in the personalization the fields from the group extensions to be expanded also, so we can see all of the details at a glance.
in addition to this if we hide some fields or sections in the personalization , the space stays empty, would be great if this could be moved so you have a smaller screen. It looks really not nive if your screen is half empty and the things you need are really at the bottom and you need to scroll down.
Also if i personalize i would like to move some fields which are on extension maybe better to the body, but it is not possible now. It is just possible to move the fields from body to body as an example
