We do have a task setup for BPM processing (BPM Action Process), not sure it's required for e-mails only? It's setup on a 15 second interval I believe?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of McMullen, Travis
Sent: Thursday, January 12, 2012 3:41 PM
Subject: Re: [Vantage] Re: PO Approver BPM
Do you need to setup a task in the task agent for send the e-mails? If so, what interval do you use?
Travis L. McMullen
ERP Specialist
ComSonics, Inc.
Harrisonburg, VA 22801
Phone: 540-434-5965 x1274
Toll Free: 1-800-336-9681 x1274
Mobile: 540-435-1920
Fax: 540-434-9847
E-Mail: tmcmullen@...
Travis L. McMullen
ERP Specialist
ComSonics, Inc.
Fax: 540-434-9847
On Thu, Jan 12, 2012 at 5:34 PM, Ken Williams < kwilliams@...> wrote:
> I would suggest using asynchronous. Synchronously pauses the client
> while the server creates and sends the e-mail, asynchronous allows the
> client to continue working and the e-mail be sent in the background.
> We use asynchronous everywhere and find it works great.
> Ken
> Sent: Thursday, January 12, 2012 3:33 PM
> Send e-mail synchronously based on the designed template.
> Travis L. McMullen
> ERP Specialist
> ComSonics, Inc.
> Fax: 540-434-9847
> On Thu, Jan 12, 2012 at 5:28 PM, epicoruser11
> <epicorusereleven@...
> >wrote:
> > What will the action be for the PO.Update Method?
> > --- In vantage@yahoogroups.com, "McMullen, Travis" <tmcmullen@...>
> wrote:
> > > The code that I posted goes in the Post-Processing for the
> > > PO.ChangeApproveSwitch. Under Actions, use "synchronously execute
> > > 4GL code".
> > > For the PO.Update, you will need a condition of "the specified
> > > field has been changed from any to any" where the field will be
> > > ttPOHeader.ApprovalStatus and the first 'any' will be 'U' and the
> > > second 'any' will be 'P'.
> > > Travis L. McMullen
> > > ERP Specialist
> > > ComSonics, Inc.
> > > Fax: 540-434-9847
> > > On Thu, Jan 12, 2012 at 4:53 PM, McMullen, Travis
> > > <tmcmullen@...>wrote:
> > > > I had to do this as well. We have the e-mail address of the
> > > > approver listed in Buyer Maintenance, so created a
> > > > Post-Processing 4GL code on
> > the
> > > > PO.ChangeApproveSwitch methond that found the buyer record of
> > > > the PO,
> > and
> > > > then found the approvers record to retrieve the e-mail address
> > > > and put
> > it
> > > > into a UDField in the POHeader. I then sent the e-mail on the
> > > > PO.Update method of the POHeader.ApprovalStatus = 'P'. The code
> > > > for the 4GL
> > portion
> > > > is below. Feel free to contact me offline with questions.
> > > > find first ttPOHeader where ttPOHeader.RowMod = "A":U or
> > ttPOHeader.RowMod
> > > > = "U":U
> > > > no-lock no-error.
> > > > if available ttPOHeader and ttPOHeader.ApprovalStatus = "P" then do:
> > > > find PurAgent where PurAgent.Company = CUR-COMP and
> > > > PurAgent.BuyerID = ttPOHeader.BuyerID no-lock no-error.
> > > > if available PurAgent then
> > > > define variable AppPerson as character.
> > > > AppPerson = PurAgent.ApprovalPerson.
> > > > find PurAgent where PurAgent.Company = CUR-COMP and AppPerson =
> > > > PurAgent.BuyerID no-lock no-error.
> > > > if available PurAgent then ttPOHeader.ShortChar02 =
> > PurAgent.EMailAddress.
> > > > end.
> > > > Travis L. McMullen
> > > > ERP Specialist
> > > > ComSonics, Inc.
> > > > Fax: 540-434-9847
> > > > On Thu, Jan 12, 2012 at 4:46 PM, Rob Bucek <rbucek@...> wrote:
> > > >> I believe youd be getting into a 4GL action there... basically
> > > >> you
> > would
> > > >> have to query to an area where you store your system user
> > > >> emails (user maintenance perhaps). Your path would be the
> > > >> ttPOdataset to the buyermaintenance dataset (I don't recall
> > > >> which tables) and ultimately linking the approval person to the
> > > >> user maintenance table. You'd have
> > to
> > > >> then code the bpm using 4gl (there are a ton of coded examples
> > > >> for
> > that on
> > > >> the group, do a search) to send an email at that point. If you
> > > >> really struggle with the query, msg me offline and I'll try and
> > > >> help you
> > flesh
> > > >> that out.
> > > >> Rob Bucek
> > > >> Production Control Manager
> > > >> PH: (715) 284-5376 ext 311
> > > >> Mobile: (715)896-0590
> > > >> FAX: (715)284-4084
> > > >> [Description: cid:1.234354861@...]<
> > > >> http://www.dsmfg.com/>
> > > >> (Click the logo to view our site)<http://www.dsmfg.com/>
> > > >> On
> > Behalf
> > > >> Of epicoruser11
> > > >> Sent: Thursday, January 12, 2012 3:35 PM
> > > >> Subject: [Vantage] PO Approver BPM
> > > >> SO I have a BPM setup that works just fine for sending an email
> > > >> when
> > a PO
> > > >> needs approval. Issue I'm running into is how I can have it
> > > >> email a
> > user
> > > >> based on who the approver should be.
> > > >> This is what i have setup.
> > > >> Method Directive setup on PO.Update Pre-Processing
> > > >> Condition: the POHeader.Approve field of the changed row is
> > > >> equel to
> > the
> > > >> True expression
> > > >> Action: send email synchronously based on the EmailPOApprover
> > > >> template
> > > >> How can I get this to send to the approver email address of the PO?
> > > >> [Non-text portions of this message have been removed]
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
