Thanks for posting this Dan. It has helped me get a working updatable dashboard to change the promise or due date on the header level and release level by unapproving and reapproving behind the scenes. You state in the pdf that you could use GetBy to refresh the results. What do you mean by this? I attempted to add another Invoke BO method widget with the PO.GetByID with the poNum binded to the ttResultsRow.POHeader_PONum and the PO table set output is ignored. This does not work to refresh as I am sure I have not set it up correctly. Could you expand on this?
Sorry for bringing up an old topic, but the help would be greatly appreciated.
