Hi All,
I’m currently facing an issue related to PO closure for partial receipt.
Here’s the situation,
A PO was partially received, then I manually closed the PO in PO Entry.
However, the PO is still showing as “open” in Time Phase.
I need to reopen this PO and then close it again for it to remove from Time Phase.
based on the standard behavior, once the PO Line/Release is closed, it should no longer appear as open in Time Phase, but that doesn’t seem to be the case.
Has anyone encountered this before? Could this be related to unfulfilled releases?
Any insights or suggestions would be greatly appreciated.
btw the version is 2023.2
Thanks in advance!
