PO Suggestions Sort Order
Is there a way to change the PO suggestions default sorting order?
I frequently encounter multiple suggestions for the same Supplier that have matching dates, but are separated by multiple lines. For Example
I’d like to put them on the same PO so it make sense to me that it would sort by Order By, Due Date, Suppli,
Once you have altered the grid to display how you like it, click the three dots on the right side, and click Save Layouts. This should save any changes to the column layout, sort order, grouping, filtering or summing. In Classic, just right click in the empty space and choose save layouts.
Note this only saves it for the one user. You would have to make this change on each PC that needs to see it.
Good luck!
No, no. Sorting in Epicor I can only sort by 1 column at a time. I want to sort by the Order by date, then sort by Supplier, like we can in Excel.
I believe this is true. If there is a way to sort on more than one column, I would love to hear it!
