I have been asked if I could do a pop up when the order entry team puts in an order and the Capacity is full for the day it is scheduled for. Meaning, they order is for 10/10, but we are already double booked for that day, so it would need to be on the next day, 10/11. Then they want an email sent to the Pre-Production Manager and the Production Supervisor. How would I go about this?
Sounds like you could handle this with an In-Transaction to Standard Data Directive.
In-Transaction:
- Put a condition to watch the order date for changes (or is initially set) and bounce out if it hasn’t changed.
- Add a code block to query the database and check if the order date is already at capacity. Assign the result to a boolean variable.
- Check the result and exit if there is capacity.
- If there’s not capacity, display an info message (non-blocking) to alert the user.
- Enable the standard directive you’ll create (below).
Standard:
- Send an email to the Pre-Production Manager and Production Supervisor with a designed template.
