Populate 'private' fields - customization question
When the order header is started was the original plan. Though I
suppose it probably makes no difference, that's just the way I
approached it.
With the lists help it's now working marvelously. Thanks for all the
tips everyone.
(As for the convert string Michael, that was just me being an
idiot....txtKeyField.Text, I realized it right after I sent my message
of course.)
Of Charlie Smith
Sent: Wednesday, January 16, 2008 10:07 AM
Subject: RE: [Vantage] Re: Populate 'private' fields - customization
question
Just for my information, are you trying to assign the Order number when
the order header is started or when the header is completed? Under
normal circumstances you would get the order number when the header is
saved. I would think you would be able to override the business process
at that point to save the order number the way you want to.
Charlie Smith
2W Technologies LLC / Smith Business Services
Behalf
Of Ken Williams
Sent: Wednesday, January 16, 2008 11:29 AM
question
Cool, almost there.
I added the two lines, verifying the guid. Now I am having issues with
converting the number.
I've tried cstr among other things and can't get it to take. Regardless
of how I try to convert it I get "Error: BC30311 - line 145 (486) -
Value of type 'Integer' cannot be converted to
'Epicor.Mfg.UI.FrameWork.EpiTextBox'." If I use cstr it says type
'String'. I've tried Chr as well, but I'm sure I need some fancy
ctype(csm.blahblah) that I don't know about. I think this is the last
step, thanks for your help!
(BTW, the reason for this button is we need two seperate order number
strings, refer to the initial e-mail if you're curious for more
details.)
Behalf
Of Michael McWilliams
Sent: Wednesday, January 16, 2008 8:52 AM
Subject: [Vantage] Re: Populate 'private' fields - customization
question
I did not know you could assign Sales Order Numbers but try this. It
will allow you to populate the field, not sure how you will be able
to get past that but if you do please let me know how.
'After the begining of the module:
Private WithEvents txtKeyField As EpiTextBox
'Then create an on load event:
txtKeyField = ctype(csm.GetNativeControlReverence(""4fceeeec-518c-
4256-932e-34a4c1a584ee"),EpiTextBox)
'Then set txtKeyField I am not sure if you have to convert your
number to a string or not.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> , "Ken
Williams" <ken@...> wrote:
> Okay, part of the problem I'm having is I'm trying to populate a
field
> before any dataview has been called.
> I'm in Order Entry and I'd like to populate the keyfield so when
they
> leave the keyfield it then creates a new SO with that number (same
as if
> you had typed an unused number in).
> I tried to create a custom control to populate OrderHed.OrderNum,
but
> that just results in a nice Microsoft .NET Framework crash.
> I did notice in the "all code" there is "Private WithEvents
> SalesOrderForm As
Epicor.Mfg.UI.App.SalesOrderEntry.SalesOrderForm" -
> beings it only shows when I select All Code, means I can't edit it
to
> make it public.
> Any other ideas?
Behalf
> Of Robert Brown
> Sent: Tuesday, January 15, 2008 3:53 PM
> Subject: Re: [Vantage] Populate 'private' fields - customization
> question
> Try declaring the dataview (containing the field you wish to pop
the
> custom calculated order number into) as Public withEvents instead
of
> Private withEvents.
> If that still fails, you are likely getting a (misinterpreted)
error
> message. Most apps seem to (randomly) have at least one field that
the
> native control just refuses to release its grip upon - so you can't
> directly reference it in a subroutine and update it.
> To get around that, assign an appropriate custom control from the
> toolbox to the field and have your Sub pass the value to the new
custom
> control (with can be hidden). That new custom control will then
set the
> field you are trying to update (without interference from the
native
> control).
> If THAT fails, set the custom control to a free (appropriate type)
user
> definable field in the same EpiDataView table as your target
field. You
> should then be able to set the edvTable(field) = to your
> edvTable(udfield).
> No idea why such machinations are sometimes required (and don't
care). I
> just know one of the 3 methods above eventually works. I suspect
the
> event trigger for the Sub doing the updating bears some
responsibility
> as to which one ends up working - as well as possibly also being a
> contributing reason as to why the native control bound to the field
> sometimes 'gets in the way'.
> Rob Brown
> Ken Williams <ken@...
> <mailto:ken%40intermountainelectronics.com> > wrote:
> We have two seperate lines of order numbers we've been using and
would
> like to continue to use. We did this originally as we had pre-
printed
> tags labeled 1000-9999 for repair work that we used as the SO
number,
> and we use the system generated ones for all other SO numbers.
We're
> reaching the end of our pre-printed tags and we'll now be printing
a
> barcode label for these, but we'd like to have them starting at
10000
> and moving forward, our system generated SOs start at 80000 so we
have a
> long time before they collide.
> So, I setup a push button on the Order Entry screen and have come
up
> with the following code:
> dim ordernum as integer = 9999
> dim recSelected as boolean = true
> while recSelected
> ordernum=ordernum+1
> Dim whereClause as string = "OrderNum = '" & ordernum & "'"
> Dim dsOrderNum as DataSet =
> Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup
(oTrans,"SalesOrde
> rAdapter",recSelected,False,whereClause)
> end while
> messagebox.show(ordernum)
> This works extremely well, but instead of just showing a message
box
> with the number, I'd like it to put this into the empty SO field
> automatically. According to customization this field is
> SalesOrderForm.sheetTopLevelPanel1.summaryPanel1.txtKeyField. If I
try
> to set this field = ordernum, I get a compiler error that the
field "is
> not accessible in this context because it is 'Private'". Is what
I'm
> asking for possible? Is there away around 'Private', or some other
way
> to populate this field?
> Thanks,
> Ken
> Looking for last minute shopping deals? Find them fast with Yahoo!
> Search.
We have two seperate lines of order numbers we've been using and would like to continue to use. We did this originally as we had pre-printed tags labeled 1000-9999 for repair work that we used as the SO number, and we use the system generated ones for all other SO numbers. We're reaching the end of our pre-printed tags and we'll now be printing a barcode label for these, but we'd like to have them starting at 10000 and moving forward, our system generated SOs start at 80000 so we have a long time before they collide.
So, I setup a push button on the Order Entry screen and have come up with the following code:
while recSelected
ordernum=ordernum+1
Dim dsOrderNum as DataSet = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,"SalesOrderAdapter",recSelected,False,whereClause)
end while
This works extremely well, but instead of just showing a message box with the number, I'd like it to put this into the empty SO field automatically. According to customization this field is SalesOrderForm.sheetTopLevelPanel1.summaryPanel1.txtKeyField. If I try to set this field = ordernum, I get a compiler error that the field "is not accessible in this context because it is 'Private'". Is what I'm asking for possible? Is there away around 'Private', or some other way to populate this field?
Ken
Try declaring the dataview (containing the field you wish to pop the custom calculated order number into) as Public withEvents instead of Private withEvents.
If that still fails, you are likely getting a (misinterpreted) error message. Most apps seem to (randomly) have at least one field that the native control just refuses to release its grip upon - so you can't directly reference it in a subroutine and update it.
To get around that, assign an appropriate custom control from the toolbox to the field and have your Sub pass the value to the new custom control (with can be hidden). That new custom control will then set the field you are trying to update (without interference from the native control).
If THAT fails, set the custom control to a free (appropriate type) user definable field in the same EpiDataView table as your target field. You should then be able to set the edvTable(field) = to your edvTable(udfield).
No idea why such machinations are sometimes required (and don't care). I just know one of the 3 methods above eventually works. I suspect the event trigger for the Sub doing the updating bears some responsibility as to which one ends up working - as well as possibly also being a contributing reason as to why the native control bound to the field sometimes 'gets in the way'.
Rob Brown
while recSelected
ordernum=ordernum+1
end while
Ken
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
Okay, part of the problem I'm having is I'm trying to populate a field
I'm in Order Entry and I'd like to populate the keyfield so when they
leave the keyfield it then creates a new SO with that number (same as if
I tried to create a custom control to populate OrderHed.OrderNum, but
SalesOrderForm As Epicor.Mfg.UI.App.SalesOrderEntry.SalesOrderForm" -
beings it only shows when I select All Code, means I can't edit it to
make it public.
Any other ideas?
Of Robert Brown
question
Private withEvents.
control).
edvTable(udfield).
Rob Brown
while recSelected
ordernum=ordernum+1
end while
Ken
Search.
field
they
as if
but
> SalesOrderForm As
to
> make it public.
> Any other ideas?
Behalf
> Of Robert Brown
> question
the
of
> Private withEvents.
error
the
custom
set the
native
> control).
user
field. You
> edvTable(udfield).
care). I
the
responsibility
> Rob Brown
would
printed
number,
We're
a
10000
have a
up
> while recSelected
> ordernum=ordernum+1
(oTrans,"SalesOrde
> end while
box
try
field "is
I'm
way
> Thanks,
> Ken
> Search.
Ahhh. I see you need to set a starting order number in company
config then you can set the order number.
--- In vantage@yahoogroups.com, "Michael McWilliams"
It
able
> field
> they
(same
> as if
OrderHed.OrderNum,
> but
> > SalesOrderForm As
it
> to
> > make it public.
> > Any other ideas?
On
> Behalf
> > Of Robert Brown
> > question
> the
instead
> of
> > Private withEvents.
> error
that
> the
can't
> custom
> set the
> native
> > control).
type)
> user
> field. You
> > edvTable(udfield).
> care). I
> the
> responsibility
a
field
> > Rob Brown
> > Ken Williams <ken@
> would
> printed
> number,
> We're
printing
> a
> 10000
we
> have a
come
> up
> > while recSelected
> > ordernum=ordernum+1
> (oTrans,"SalesOrde
> > end while
> box
I
> try
> field "is
> I'm
other
> way
> > Thanks,
> > Ken
Yahoo!
> > Search.
Cool, almost there.
details.)
question
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Ken
field
they
as if
but
> SalesOrderForm As
to
> make it public.
> Any other ideas?
Behalf
> Of Robert Brown
> question
the
of
> Private withEvents.
error
the
custom
set the
native
> control).
user
field. You
> edvTable(udfield).
care). I
the
responsibility
> Rob Brown
would
printed
number,
We're
a
10000
have a
up
> while recSelected
> ordernum=ordernum+1
(oTrans,"SalesOrde
> end while
box
try
field "is
I'm
way
> Thanks,
> Ken
> Search.
Try this:
Dim strOrderNum As String = ordernum.ToString
txtKeyField.Text = strOrderNum
> Cool, almost there.
with
Regardless
last
number
> details.)
Behalf
> question
It
able
> field
> they
(same
> as if
OrderHed.OrderNum,
> but
> > SalesOrderForm As
it
> to
> > make it public.
> > Any other ideas?
> Behalf
> > Of Robert Brown
> > question
> the
instead
> of
> > Private withEvents.
> error
that
> the
can't
> custom
> set the
> native
> > control).
type)
> user
> field. You
> > edvTable(udfield).
> care). I
> the
> responsibility
a
field
> > Rob Brown
> > Ken Williams <ken@
> would
> printed
> number,
> We're
printing
> a
> 10000
we
> have a
come
> up
> > while recSelected
> > ordernum=ordernum+1
> (oTrans,"SalesOrde
> > end while
> box
I
> try
> field "is
> I'm
other
> way
> > Thanks,
> > Ken
Yahoo!
> > Search.
Charlie Smith
Of Ken Williams
question
Cool, almost there.
details.)
Behalf
question
field
they
as if
but
> SalesOrderForm As
to
> make it public.
> Any other ideas?
Behalf
> Of Robert Brown
> question
the
of
> Private withEvents.
error
the
custom
set the
native
> control).
user
field. You
> edvTable(udfield).
care). I
the
responsibility
> Rob Brown
would
printed
number,
We're
a
10000
have a
up
> while recSelected
> ordernum=ordernum+1
(oTrans,"SalesOrde
> end while
box
try
field "is
I'm
way
> Thanks,
> Ken
> Search.
