Add Purchase Point to your report. I did a similar search two weeks ago,
where the Report Builder Report showed a receipt, but I couldn't find it in
Receipt Entry. I finally discovered Purchase Point...
Sent: Thursday, August 17, 2000 10:59 AM
To: 'vantage@egroups.com'
Subject: RE: [Vantage] PO's Received but Not Invoiced
Dan - you ask a tougher than usual question. I've done some such
clean up
myself. However, when you said the receiver isn't there when you
look for
it in invoice entry and yet it shows on the report............
That's when
it really gets rough to help. Here's my shots in the dark.
The ONLY two things I can think of are: 1) verifying the accuracy
of the
report itself or
2) verifying the Vendor ID for listing the receipts on the report.
Such
examples might include a company name like The Morley group and
searching
under both T and M. Another example is that we have customers set
up as
both vendors and customers in the Vendor file - with two different
IDs.
(Customer furnished material leads to such odd behavior and some
customers
are vendors and customers both.) Look for the receipt under both
(all) ids.
Our PO's rec'd but not invoiced report states the Vendor ID to aid
in
finding those outstanding receipts. This has really helped me in
clearing
out such items as you described. (This also helps with item #1 -
verifying
the accuracy of the report.)
Good luck and please let us know what the other options to
investigate are
once you have solved this riddle.
Sincerely,
Deb Wilmoth
Reeder & Kline Mahcine Co., Inc.
Subject: [Vantage] PO's Received but Not Invoiced
Can anyone tell me how to clear items out of this report that are
mistakes.
This report is suppose to be the detail of the A/P Clearing account
in the
G/L. When I ran this report I found open items that have been paid
as a
miscellaneous invoice and not matched with the packing slip. The
P.O. is
closed and the Packing Slip is closed and when I go to invoice entry
to
match up with receiver it is not there. Epicor has been of no help
as
usual, they are referring it up to program control.
We no longer allow attachments to files. To access/share Report
Files, please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try
it, go to www.egroups.com, login and be sure to save your password, choose
My Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
clean up
look for
That's when
of the
report itself or
Such
searching
up as
IDs.
customers
(all) ids.
in
clearing
verifying
investigate are
Sincerely,
Deb Wilmoth
mistakes.
in the
as a
P.O. is
to
as
