I loaded the software and set the path for prowin32.exe, and I'll be - it works!
Excellent tip. Thanks.
Eric L. Tyira
Tamglass Tempering Systems
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
Sent: Friday, June 25, 2004 8:09 AM
Subject: RE: [POSSIBLE SPAM] RE: [Vantage] Re: Ot: Intellipoint softwarever5.0
Thanks.
I misread you post. I thought you were saying the software was for the
outlook problem only.
Sent: Thursday, June 24, 2004 7:03 PM
softwarever5.0
Edward,
After you install the utility, it will put a little icon in your system tray
(looks like a white C with a blue center). If you right-click on that icon
and select 'Parameters', you'll get the list of all the applications it is
hacking wheel mouse support for ('Sample' will be there by default). To set
it up for Vantage, go to 'Program', 'New', fill in a description, and set
the path to prowin32.exe. Now that should cause all applications that use
prowin32.exe to use the wheel mouse hack (the shortcut you launch from does
not matter).
In case the Outlook Address Book thing is a problem for you too, I found
that telling it to take over for all of Outlook.exe was a bit too much
(since most of Outlook worked fine with the wheel mouse). I instead opted
to have this utility only step in for the address book window. That is
accomplished by unchecking the 'Path' box, checking the 'Window Title' box,
and filling in whatever the title of the window is that is broke (I belive
it was 'Select Addresses').
Take care,
Adam
Yahoo! Groups Links
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129p4dtg0/M=298184.5022502.6152625.3001176/D=groups/S=1705007183:HM/EXP=1088251790/A=2197946/R=0/SIG=11elgumq7/*http://www.netflix.com/Default?mqso=60183367> click here
<http://us.adserver.yahoo.com/l?M=298184.5022502.6152625.3001176/D=groups/S=:HM/A=2197946/rand=543963202>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of <http://docs.yahoo.com/info/terms/> Service.
Eric L. Tyira
P: (856) 786-1200
F: (856) 786-7606
eric.tyira@...
Thanks.
softwarever5.0
Edward,
not matter).
Take care,
Adam
> Adam,Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> As usual, you are a wealth of knowledge. Where are you making that
> setting? In the shortcut?
> Thanks
> From: Adam Ellis [mailto:aellis@...]
> Sent: Wednesday, June 23, 2004 3:31 PM
> To: Vantage Mailing List
> Subject: Re: [POSSIBLE SPAM] RE: [Vantage] Re: Ot: Intellipoint
> softwarever5.0
> Importance: High
> I was having a similar problem under XP. The problem occurred for me
> both in Vantage and in Outlook address book. I found this software to
> resolve the issue:
> http://www.ardamax.com/info_mwc.html
> For Vantage, set the application to be V:\Progress\bin\prowin32.exe
> (where V is the drive to your Vantage install). Not an ideal fix, but
> it works.
Yahoo! Groups Links
ADVERTISEMENT
_____
Yahoo! Groups Links
