Hi Kevin,
Thank you for the suggestions - good food for thought as far as philosophical approach and design....
We'll see how the low-tech printing solution works for now, and look at more sophisticated options if that doesn't work.
Thanks again!
Laraine
Thanks again!
Laraine
--- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@...> wrote:
> Laraine,
> Another option you may have that is completely in another direction: write
> some VB code in your customization of the MES menu. If someone tries to
> close the form, capture that event and see if they're logged out. If
> they're not, give them a warning and prevent them from closing the form.
> This wouldn't capture 100% of your issues, someone could use task manager
> for example to kill off the form. However, I implemented this change with a
> client and it greatly reduced the number of times people left themselves
> logged in, where it's barely an issue now.
> Kevin Simon
> SimsTrak Consulting
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> laraines422
> Sent: Friday, November 04, 2011 11:40 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Possible to set a time trigger for an event?
> Hi All,
> I'm stumped on this one, but I'm hoping that someone reading this will have
> a solution.
> We're on Vantage 407c. We run two shifts in our Machine Shop, basically from
> 6 AM to 12:30 AM the next day. We occasionally (!) have staff that fail to
> clock out of MES, but we won't know that until well after the fact.
> Hypothetically, no one should be clocked in between 12:30 AM to 6 AM - so
> I've written a BAQ report that runs at 3 AM every morning, to indicate any
> MES user still clocked in. This report works fine and provides what we need.
> But rather than printing this report, what I would prefer is a BPM that
> would fire off at 3 AM, look to see if there were any active MES
> transactions and fire off an email alert to the MES Supervisors.
> Is it possible to trigger a Business Object (BO) using a time setting, which
> could then activate a BPM?
> Thanks in advance -
> Laraine
