Posting Rule from scratch
We have created a new posting rule on the COS/WIP to update couple of UD fields on the Gljrndtl and Rvjrntrdtl . The rule contains only the lines to update the UD fields and nothing else. Its selection is given as for each Parttran, since we are taking information from the partmaster for the UD fileds. The reference entity is given as COSAndWIP-Parttran-Detals.The values are getting populated when we are looking at the PE log but its not hitting both the Rvjrndtl and GLjrndtl tables.
If we give the same operations inside any existing rules , it works fine .
Whats that we are missing ?
Did you ever get a solution here? I’m trying to do something similar
