I’m trying to prevent the existing code from being selected when a particular control gets focus. I’d like no selection to exist, and the cursor to be placed at the end of the text.
I set txtTest1.GotFocus() to just have the following line: txtTest1.Text = "Set via GotFocus()";
The idea was to see if that controls text was being selected before or after the GotFocus() executed. But now my GotFocus is acting more like LostFocus. If I tab to the control, the existing text doesn’t change. but when I tab out of that control, the text changes to my static value. Even if I had manually changed the text before tabbing out.
I see the same thing, weird, I know the focus events can be inconsistent.
At the Winforms level GotFocus and LostFocus are low level events that msdn recommendeds to not use. They recommend using Enter and Leave, which perform predictably in Epicor.
