Thank you all.
Mario Aguirre
Information Systems Manager
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Sent: Wednesday, January 02, 2002 12:02 PM
Subject: [Vantage] Re: Print Filtered Date Ranges in Report Builder
Another "neat" feature I always like to add in the summary line is"
Report Library and Report Name.
You create it the same way: Calculated Field
I usually call my field name: Rpt_Name
Expression: Just 'click' your cursor into this field -then in
functions select Report-Name()-Then OK
Do the same for Report-Library()
Nancy Ann Riffle
Aspacia Systems Inc
952-930-9066
Mario Aguirre
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Nancy Ann Riffle
Aspacia Systems Inc
952-930-9066
--- In vantage@y..., Matt Finn <matt@s...> wrote:
> Yes...sort of. If you can live with the whole filter in the report
then:
> You have to add a calculated field.
> Then from the functions box select REPORT-FILTER().
> You can then place the newly created field in your report.
> Otherwise:
> You can add two calculated fields and use Min and Max to get
> only the dates.
> From: Mario Aguirre [mailto:maguirre@l...]
> Sent: Wednesday, January 02, 2002 10:47 AM
> To: 'vantage@y...'
> Subject: [Vantage] Print Filtered Date Ranges in Report Builder
> I hope everybody had fun over this long weekend and Happy New Year
to all.
> Is there a way to print filtered date ranges in a report in Report
Builder?
> For example: I filter from 12/23/01 to 12/29/01. I want to print
those dates
> in the header of the report. Any ideas?
> Mario Aguirre
> Lakin General
> 2865 N. Paulina
> Chicago, IL 60657
> Ph: 773-871-9631
> Fx: 773-871-1265
