Print label at job receipt to inventory?
I'm very interested to hear your progess as we need to do this same thing. Please keep us posted.
Jared
So, we need to start printing part labels at job receipt to inventory because we're implementing lot tracking for various parts.
As some of you probably know, there is no way to print a label on this screen. So, has anyone tackled this in any way. Wondering if there's a way to capture all the data on the screen and pass it to either Crystal or Bartender.
It would have to be done on screen likely since after you perform the receipt, the screen clears - and we don't want to perform it for all jobs/parts all the time. I'm guessing a button to pass the screen values would be the best solution.
Yes, you can do this with Bartender and customization.
If you have more details on the fields and the label I could help more.
Basically, we're trying to reproduce the base part tag that Epicor generates at various other places, so in this case for the job receipt, I'm thinking:
Part Number
Part Type
Lot Number (if one there)
Warehouse
Bin
The label is likely going to be a Zebra label printer, but I think if I can get it simply printing to any device initially from a button for testing I can get the rest working.
Here is an example. You would create a Bartender label with all the fields and have LotNumer as an input Parameter. If you were doing it just for a part without a lot number use the PartNum as your variable.
Dim PartTran As EpiDataView = Ctype(oTrans.EpiDataViews("PartTran")EpiDataView)
Dim Printer As String = "{PrinterName}"
'//We hardcode the printer in)
Dim LotNumber As String = PartTran.dataView(PartTran.Row)("LotNum")
Dim strPath As String = "C:\Progra~1\Seagull\BarTender\8.0\bartend.exe"
Dim strParam As String = "/F=C:\Tags.btw /PRN= /P /X /?LotNumber="&LotNumber
'// (Tags.btw is the name of our bartender file, LotNumber is the parameter in the file as well as your variable)
Dim strParam2 As String = strParam.Insert(20,Printer)
'// Inserting the printer into the parameters at the 20th position.
'// If your file name is longer you will have to modify.
Process.Start(strPath, strParam2)
> Part Number
> Part Type
> Warehouse
> Bin
Okay... will be attempting to get this working today, we'll see how it goes.
> > Part Number
> > Part Type
> > Warehouse
> > Bin
