Check this out.
<mailto:rburroug@...>
http://www.hurricanesoft.com/ <http://www.hurricanesoft.com/>
Greg Clauser
Lakin General Corporation
gclauser@... <mailto:gclauser@...>
Sent: Thursday, September 07, 2000 1:50 PM
To: vantage@egroups.com
Subject: [Vantage] Print Preview alternative
<http://click.egroups.com/1/7750/13/_/411782/_/968352819/>
<http://adimg.egroups.com/img/7750/13/_/411782/_/968352819/benefitsblue_new5
.gif>
<http://www.egroups.com/> eGroups My
<http://www.egroups.com/mygroups> Groups | vantage Main
<http://www.egroups.com/group/vantage> Page | Start a
<http://click.egroups.com/1/8150/13/_/411782/_/968352819/> new group!
Is anyone using an alternative program for Print Preview-ing in
Vantage? You know... all those Progress programmed reports that come up
in that miserable window that can't be maximized or copied & pasted from?
You can specify the program of your choice in Vantage.Ini. Plain old
WordPad works, but doesn't offer a single key print function. I went out
looking for share-ware text editors that could be used, but haven't had
time to locate & evaluate many. So I thought I'd run it by y'all.
Ideal specs / requirements:
* Able to specify file pathname on command line.
* Window can be maximized or sized as desired.
* Regular windows "copy" functionality available.
* Quick & easy "print all" function; maybe via customizable tool bar.
* Ability to print a selected range of pages.
* Able to specify file as read-only.
* Global (& lockable) config file to specify screen & printer fonts,
margins, above parameters, etc.
Any suggestions? Mike... wanna write one :)
-Wayne Cox
<http://www.egroups.com/files/vantage/>
Greg Clauser
.gif>
-Wayne Cox
