Print settings default
We have defaults set for the output to be PDF and our custom as the report style and it works as intended. Unfortunately, I have a single user who is unable to get any options, let alone the defaults, to populate. 1024 isn’t even a valid report style. The second picture is how it should look.
I’ve cleared the cache, had the user log all of the way out and switch from Edge to Chrome. Same result. There are no personalizations for this user on this screen. What else should I be checking?
What happens when they click on Report Style? Does it show the proper list? If so, then it could be a corrupted default have them try deleting it:
I also just had a user have this issue when trying to print a Quote. We got through it by selecting a report style and actually clicking Save Defaults.
He then closed the print form and reopened and all was good.
We then went in and hit the “Remove Defaults” and nothing appeared to change… but, again, it was working fine at that point.
So… as @Randy mentioned… try toggling either Save Defaults and/or Remove Defaults. That worked for us.
That worked! Thank you!
