What are you using to print your drawings/files at the same you print the traveler or picklist.
Did you ever get an answer for this? We have been wanting to do this for a while, but have not yet gotten it to work.
No. but I did have consultant give me some ideas, so there is a way.
We print our drawings with Job Traveller which are in crystal. The drawings are attached to the part revision, so that when the job is made and we get details from the part revision the drawing is copied over to the job.
The drawings are all saved as wmf since that was the only format crystal could work with. SSRS might be different. It has been working fine for a few years now.
Vinay Kamboj.
We use Crystal as well, but we pull in PNGs instead of wmf. There’s another thread about this topic that discusses using Crystal along with other options:
