Ah haaaa. I think I see the issue. Last time I looked a tquoting was in 5.2 and it used an array. In 6.1 I see the new QSalesRP table. I think I see where you are going with this.
Two get two seperate QSalesRP records on the same band line you may need to create an alias table for the QsalesRP table. In you linking link to that table again (using the desired alternate key value) and give it an "alias" table name (like QSalesRP2). Then in the report refer to the original and the alias for their respective values.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Eunice Corral
Sent: Thursday, June 15, 2006 10:54 AM
Subject: RE: [Vantage] Printing Salesman & Quoter in the same line - Report Builder
Thank you Todd, but what I need to print is the SalesRepCode
itself,
Example: SalesRepCode = "boc" Quoter PrimeRep = No
SalesRepCode = '06" SalesPerson PrimeRep = Yes
This two ID's are in the Quote under "People" but both share the same
field for RB, SalesRepCode,
and I would like to print in one column "boc" and another column "06".
Could that be possible?
Eunice Corral
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf
Of Todd Caughey
Sent: Thursday, June 15, 2006 10:21 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Report Builder
Response based on 6.1.
SalesRepCode is an array type field which can hold up to 5 reps. The
values are seperated by the ~ (tilde) character. When dealing with it I
have always had to parse out the individual values (in RB using the
ENTRY function). If you only ever have one per quote you can pick out
the first X characters and ignore the rest. The tilde character is ASCII
126.
-Todd C.
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com> ]On
Sent: Thursday, June 15, 2006 10:14 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com>
Cc: Ken Kveton
Subject: RE:[Vantage] Printing Salesman & Quoter in the same line -
Report Builder
I am designing a report and I would like to have the Quote
number in one column, the Quoter in the second
column, and the Salesman in the third column. As everyone
knows the Quoter and Salesman are both
"SalesRepCode", all I need is to print the SalesRepCode.
I am trying the following: IIF(QSalesRep.PrimeRep = yes,
QSalesRep.SalesRepCode, "")
But it will not print the SalesRepCode at all. I appreciate
if anyone responds to this message with any
suggestions you may have.
Eunice Corral
Dudek & Bock Spring Mfg. Co.
773-379-4100
-Todd C.
itself,
Eunice Corral
Of Todd Caughey
Report Builder
126.
-Todd C.
Cc: Ken Kveton
Report Builder
Eunice Corral
773-379-4100
