I am using UD05 to contain information extracted from Avalara Cert Capture and display it on the Customer Entry screen. Avalara uses the date 12/31/9999 in a date field to indicate that a certificate never expires. I can use DMT to successfully import 12/31/9999 into UD05. I can use a BAQ to correctly display the value 12/31/9999. But when the same date field is attempted to be displayed in an epiDatetimeEditor in UD05 Entry Program, there is an error and the field shows blank:
Message: Date Time Notification Exception: UD05.Date02(12/31/9999), source data value is invalid
Inner Exception
Message: The control’s value cannot be set outside the range determined by the ‘MinValue’ and ‘MaxValue’ properties.
I can enter and save a value of 12/31/9998 in that field, but not any dates in 9999.
Is there any way to change the MaxValue of that epiDateTimeEditor?
If I change that field display to a TextBox, it displays like this:
Is there a way to change the format to just show the date, not the time?
Another approach is to intercept the text extracted from Avalara and substitute 12/31/9998 for 12/31/9999 before Epicor even knows about it. (I don’t think that one year will make a difference in 9998!)
Is there any other approach I should consider?
