Someone in this group helped me out with a similar issue - thanks
Hope this works for you....
Open report in Crystal and get the section expert running.
Look at each section from the report header on downward (click on it
to make it turn blue) Watch the tabs on the right side - you will see
one say Layout when you find the correct section (Detail??) Click the
layout tab and see what size the section is set to be... Adjust as
necessary.
HTH
necessary.
HTH
--- In vantage@yahoogroups.com, "adamtuliper" <amt@...> wrote:
> tried that already, thanks though. The report itself is running
large
> for some reason - ie theres invisible space being taken up
> somewhere... and lots of it (Several inches)
> I can reproduce the problem by printing to 8.5x11 and then
decreasing
> the page size. it bombs below about 6.5 inches in height, but the
> last text (which is the part number bar code) ends at about 1.5
> inches.. .so don't know why it thinks there is 5 more inches to the
> report that it needs.
> --- In vantage@yahoogroups.com, "Roger@" <rjr-office@> wrote:
> > I find that when printing labels that you need to set the margins
> to 0
> > on all four sides.
> > roger Rabus
> > Logical Solutions
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of adamtuliper
> > Sent: Thursday, March 15, 2007 1:49 PM
> > Subject: [Vantage] Problems printing with Intermec PC4
> > At Epicor's recommendation, we have purchased the PC4 printer.
> > Unforuntately we cannot get our tags to print to this printer.
> Epicor
> > support won't help and say call crystal - thanks. The inspection
> tags
> > for example, seem to print out (the visible size of the data) on
> paper
> > at 3.5 inch by 1.5 inches (when printing to 8.5x11) , yet
printing
> to
> > 4x4 fails. Not sure why since the visible data is quite small.
> We've
> > installed the printer on the server and tried it from there -
> setting
> > the 4x4 paper size in the page setup (we defined a custom 4x4
size
> for
> > intermec). Then we come out of page/printer setup in crystal and
> > immediately makes the report invalid and you cant see anything.
> Crystal
> > then gives a message "The page size was not large enough to
format
> the
> > contents of an object inthe report". If we go 4x6.5, then it
seems
> to
> > work, but yet the visible data on our report is about 3.5x1.5.
Ive
> > tried clicking around in crystal as well on the previewed report
to
> see
> > if anything extends beneath the bottom of the visible data but
> nothing
> > is there. Any thoughts?
> > Thanks,
> > Adam
