Problems with Progress 9.0B patch 44 installation
I am having the same problems. Vantage support thought it may be a corrupt
download. OOPs!!! I guess not.
Thanks for the heads up.
Darren Mann
> -----Original Message-----
> From: phoorn@... [mailto:phoorn@...]
> Sent: Wednesday, November 08, 2000 4:04 PM
> To: vantage@egroups.com
> Subject: [Vantage] Problems with Progress 9.0B patch 44 installation
> Has anyone loaded the 9.0B 44 patch yet?
> My installtion took a lot of time and resulted in an error message:
> can't write file, disk full? I started with over 2.5 Gigs free on te
> disk. After a couple of tries it was reduced tot 250 megs. After I
> deleted the .tmp file in the bin directory it seems to be ok now. The
> patch level is 44, but I'm still not sure wether everything is
> correctly installed. The installation program took a lot of time
> installing prow32.dll (at 8%)
> -------------------------- eGroups Sponsor
> eLerts
> It's Easy. It's Fun. Best of All, it's Free!
> http://click.egroups.com/1/9699/5/_/411782/_/973721094/
> -------_->
> We no longer allow attachments to files. To access/share
> Report Files, please go to the following link:
> http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you
> try it, go to www.egroups.com, login and be sure to save your
> password, choose My Groups, choose Vantage, then choose
> Files. If you save the password, the link above will work
> the next time you try it.)
We ran into the same, except that i cancelled the installation after 5
minutes at 8% (prow32.dll) and pushed the reset button :-(
Back to 90B37...
Hendrik Stasik
hstasik@...
http://www.deltatechmold.com
